Should I replace my water pump?
Old Mar 26, 2014 | 12:35 PM
robot808's Avatar
Default Should I replace my water pump?
Hello all.
I just bought a high mileage (142K miles) 98 XJ8. It just had the TB chain tensioners and transmission drum jobs done months before I purchased it.
I have no idea about the water pump.
Should I just change it and be done? Do I wait for some symptoms?
If I do change it, what else is mandatory WYIT stuff, and what is optional?
I don't mind spending a some money and time making it right, but I don't want to spend money, just to spend money.
Thanks for any help,
Old Mar 26, 2014 | 12:52 PM
vincent661983's Avatar
i just learned a few hard lessons that waiting until the issue breaking down entire car's mechanism and a costly fix. just my opinion
wont hurt as a preventive measure
Old Mar 26, 2014 | 01:09 PM
bigcat777's Avatar
Waterpump, T-stat, and metal housing replacement/upgrade is a cheap date. DIY project Bb. Just my 2 cents
Old Mar 26, 2014 | 01:14 PM
JimmyL's Avatar
I agree with bigcat, and throw in the serpentine belt. Not a bad job, not a lot of money, worth the peace of mind. The only tricky part is the bolts for the t-stat housing and there are a bunch of posts about that.
Old Mar 26, 2014 | 01:40 PM
98 XJ8's Avatar
I would say do it! About $100 for a new water pump and $50 for a new metal T-stat housing which in the long run will save you from a blown head gasket. I've heard of the fins on the water pump falling apart because they are plastic originally and blowing the head gasket. A revised pump should have steel fins. Bad water pump might give no warning...
Old Mar 26, 2014 | 01:58 PM
robot808's Avatar
Ok, so I'm in. I will be doing it myself.
Do I need to do hoses, belt tensioner and pulley as well? Obviously I'm replacing the coolant.
All of these things necessary?
Old Mar 26, 2014 | 02:00 PM
mcm97's Avatar
cant hurt. To me that's a "while you're in there" sorta fix so why not?
Old Mar 26, 2014 | 02:19 PM
robot808's Avatar
Well, the obvious answer is because it costs more. Not that I won't do it, but lots of things want my money...
Old Mar 26, 2014 | 02:43 PM
RJ237's Avatar
The belt tensioner and idler are easy enough to do separately if they make noise, and are not likely to result in catastrophic failure. Make sure you get a new thermostat with the housing, they tend to fail in closed position.
Old Mar 26, 2014 | 02:48 PM
RJ237's Avatar
Forgot hoses. The octopus is a big job, but the short one to the cross connector definitely, and take a careful look at that plastic connector, it gets brittle with age. The other hoses at least should be inspected.
Old Mar 26, 2014 | 02:53 PM
robot808's Avatar
I'll start ordering parts.
I've been searching, can anyone tell me where to find the best write-up for this job?
Thanks again, guys.
Old Mar 26, 2014 | 02:55 PM
mcm97's Avatar
More than a fair response. I just remember on my e46 it seemed like stuff I didnt replace would crap out two weeks later. That car was a mess in general though
Old Mar 26, 2014 | 05:52 PM
robot808's Avatar
The last thing I want to do is be penny wise and pound foolish, but since I am not even sure that my car needs the service, I do not want to throw more than I have to at it.
I just figured with the chain tensioner, transmission drum, and the waterpump all addressed, (plus the lower ball joints I just ordered) that I'll have a pretty good start.
Sprayall
May 30, 2021 08:13 AM
Charlene n John
Sep 28, 2015 06:01 AM
Charlene n John
Sep 6, 2015 11:03 AM
Sprayall
Sep 3, 2015 07:49 PM
KarimPA
Sep 3, 2015 07:32 PM
