simple bulb replacement complicates everything
Old Feb 23, 2020 | 10:21 PM
ROWKID's Avatar
Default simple bulb replacement complicates everything
Hi Guys, I had a bulb go out on the dash cluster in my 2002 Jaguar Vanden Plas. Following instructions I disconnected the neg battery cable and exchange the bulbs for new ones. I reconnected the battery after assembling the cluster and started it. I immediately got alerts. Oil pressure low,(checked level and it is down almost a quart) antifreeze low (I checked and its full) battery not charging?? and the fuel guage is not working. Did I make an error connecting the cluster when reinstalling after changing the bulbs? Is there a connection to the fuel gauge behind the cluster? I heard about a possible ground problem with the cables to the battery so I will check those. Is there anyone who recognizes these symptoms? I thought the bulb replacement went well.. until now. Such a simple repair shouldn't cause this much angst! Thanks so much.
Michael
ROWKID
2002 Vanden Plas
Old Feb 23, 2020 | 11:09 PM
avern1's Avatar
An error we have seen before. Remove the cluster and reseat the connectors. The latch will close but the connector is not correctly seated. Make sure you have a good connection before engaging the lock lever.
Old Feb 24, 2020 | 08:56 AM
ROWKID's Avatar
Thanks aver1 for your reply. I was thinking along those lines. I’m taking the cluster out again and will adjust the connections. Hopefully she’ll be back and running without the errors. I will keep you posted. Best, Rowkid
The day I bought her with 86k miles.
Old Feb 24, 2020 | 09:59 PM
ROWKID's Avatar
Default Reinstalled cluster
I installed the gauges cluster after changing the bulbs. There are two plugs on bottom at both sides. I didn’t seat them properly and this caused a few CEL warnings including battery not charging and low oil pressure. After removing the cluster again I was able to re seat the electrical plugs and now everything is working fine. Thanks again to this forum for the help. Rowkid
Old Apr 19, 2020 | 11:48 PM
01XJVP's Avatar
what bulbs did you use? i have a bulb out and dreading this
Old Apr 20, 2020 | 08:35 AM
xalty's Avatar
they’re 194s, 3W
Tracy Weiland
Aug 28, 2016 11:34 PM
seawind
Sep 19, 2014 03:52 PM
Vinnyboy
Aug 7, 2013 05:47 PM
Stamford
Aug 25, 2012 09:07 PM
Montauke
Dec 5, 2010 01:53 PM
