Where is middle brake light wiring connector? 2000 xj8 vdp L
Old Apr 20, 2020 | 06:40 AM
Joe Enge's Avatar
Default Where is middle brake light wiring connector? 2000 xj8 vdp L
Got my chrome wing on the front bumper installed, waxed the grille, and fixed both headlight surrounds yesterday. Now focused on this middle brake light. It’s laying on the rear deck, and has a dozen cracks.
My solution is to build a box for it to sit in, resting and held steady by dowel rods, felt stickers to prevent any rattling, and to use chip wood as a filler on the rear facing plane. I found a cherry minwax that is pretty close to my interior wood moulding.
For this to be halfway decent looking and fitting, I need to remove the brake light and build the box around it. I don’t see a connector when I pull the wire. Before I uninstall my subwoofers in the trunk, to look for a connector above the gas tank, I’m wondering where the connector should be.
ive read that some don’t have connectors, so maybe mine doesn’t. The ones that I’ve seen for sale have a connector after maybe 6” of wire. I can pull maybe 9”, but no connector. So... maybe these were added?
basically, if I do have a connector, where should it be?
thanks!
Old Apr 20, 2020 | 07:29 AM
King Charles's Avatar
It's below the rear parcel shelf.
Old Apr 20, 2020 | 07:30 AM
Joe Enge's Avatar
So I need to go through the trunk then?
thanks
Old Apr 20, 2020 | 07:31 AM
https://www.jaguarforums.com/forum/x...advice-225571/
Old Apr 20, 2020 | 08:15 AM
Joe Enge's Avatar
Oh no, exactly what I was afraid of. I do need to remove the blown subwoofer on the deck though...
thanks much
Old Apr 20, 2020 | 08:13 PM
64etype's Avatar
Originally Posted by King Charles
Hey, cool photo! ( It's my car). Taken during the fuel pump removal. I spotted the sealant around the access hole that I chopped in the shelf during the fuel pump change out. For the OP...you will have to remove the right seat belt retractor to angle the shelf finisher out. The seat belts have to be released at the bottom and then threaded through the slots at the top of the seat back cushion as you remove it. Helps if someone can help you muscle the seat cushions around and out.
TN8Shooter
Aug 6, 2020 04:14 PM
Pylens
Jan 31, 2017 04:33 AM
adriaxj8
Dec 13, 2012 05:20 PM
Oldengineer
Jul 15, 2009 09:19 PM
