Speakers size on '01 XJ8 VDP
Old Jan 28, 2011 | 11:02 AM
meaculpa's Avatar
Question Speakers size on '01 XJ8 VDP
I need to replace front doors speakers on my 2001 VDP - Alpine system. What size should I get (I found contradicting answers), is it a direct plug & play replacement, do I need a mounting ring and a good link for where to get them. Thank you
Old Jan 28, 2011 | 11:47 AM
JaguarXJR02's Avatar
this might not be the exact information you are looking for, but a factory replacement comes in at $65 from this dealership near washington DC
this website is inconvenient since it does not allow you to post a direct link, but you go here:
http://www.expresspartscenter.com/
scroll down a wee bit, then put in your car information
then on the next page you will see a list of categories on the left side, pick "console" then it takes you to another menu where you can pick "sound system" then choose "speaker" then choose "Front door"
I ordered a new parcel shelf subwoofer speaker from them and so far so good, it is an OEM alpine speaker replacement.
good luck
Old Jan 28, 2011 | 12:18 PM
meaculpa's Avatar
Thank you JaguarXJR02. The problem with the link you posted is that they have standard and premium systems listed. Which one is mine? I got the Alpine system...should be premium, right?
Old Jan 28, 2011 | 02:08 PM
DavidN's Avatar
You've got the premium system.
(according to the pictures of the eBay auction).
Cheers,
David
Old Jan 28, 2011 | 03:53 PM
meaculpa's Avatar
If I want something better/aftermarket, what size should I get? Thanks
Old Jan 29, 2011 | 02:40 AM
DavidN's Avatar
I don't know if the size of the premium speakers is the same as of the standard system, so the following information might not be suitable for your VDP.
Before I changed my speakers I took measurements of the speakers...
I have the standard sound system with no amp in the trunk and no tweaters in the a-column.
I exchanged all 4 door speakers to Magnat 2-ways and I am VERY happy with the outcome!!
I used Magnat XTR 216 and they are a perfect fit!
Attached are some pics I took of the old speakers...
HTH!
David
Old Jan 29, 2011 | 03:40 PM
meaculpa's Avatar
I decided on Polk Audio from Crutchfield:
http://www.crutchfield.com/p_107DB65...1s.html?tp=105
Thanks!
aholbro1
Dec 29, 2024 06:46 PM
kevinl
Oct 31, 2019 06:15 PM
Gerard Radimaker
Sep 13, 2015 10:33 AM
wcourt3010
Sep 9, 2015 04:34 PM
