Speedo problem....
Old Sep 9, 2020 | 12:25 PM
cityboy's Avatar
Default Speedo problem....
My speedometer in the 01 XJ8 one day works, next day doesn't. Has just started playing up like this over the last week. My ABS unit is out for repair but the speedo worked for sometime after removal. I suspect the VSS, JLM11251. Anybody have experience here?
Old Sep 9, 2020 | 03:07 PM
avern1's Avatar
I believe the part you are referencing is involved in controlling the transmission. The speedometer receives it signal, if memory serves me, from the left rear wheel speed sensor. I would recommend removing and cleaning the sensors for all wheels and while doing it inspect the relucter rings for excessive corrosion.
Old Sep 9, 2020 | 03:13 PM
xalty's Avatar
so is this car has no ABS module in it?
Old Sep 10, 2020 | 08:12 AM
cityboy's Avatar
i have the bad module in it.
Stu Jags
Sep 17, 2019 05:37 PM
monty14b
Jul 7, 2019 08:32 PM
XxSlowpokexX
Oct 18, 2014 10:25 PM
davea9988
Jan 4, 2014 04:23 AM
victorpalm
Mar 6, 2011 02:16 PM
