Squeal from back right wheel? Brake pads?
Old May 24, 2013 | 12:43 PM
Brettl's Avatar
Default Squeal from back right wheel? Brake pads?
I think it's a brake sensor but not sure. Slight squeal but seems to go away when braking. I hear it when coasting with windows down. If it is brakes and the pads need replaced what brand works well on a 98 VDP? I hate brake noise so I want a brand - no squeaking - even if they are soft and I have to replace more often.
Oh if you think it's something other than the brake pads let me know.
Old May 24, 2013 | 01:12 PM
Jhartz's Avatar
I like Wagner Gold ceramic: quiet, clean. have worked well on my 308, as well as my last RRS/SC.
Old May 24, 2013 | 01:50 PM
Have you checked for a squirrel sitting on the axle?
OTOH, you say that the noise goes away when the system is under load (braking) but is evident when coasting.
Apart from checking your pads, I'd also check the drive line for a wobbly wheel bearing, prop bearing etc.
Why, because under braking pressure the whole system loads up and can tighten things to mask the loose part.
(Back when I was a student, working in a garage part time, we had one car that ran into the garage 'literally', the owner an elderly guy had 'greased' his discs to stop them from rusting, worked well, no squealing either!!)
BrentGardner
29
Dec 16, 2024 12:13 AM
RaceDiagnostics
Dec 11, 2015 10:12 AM
ronald4313jm
Aug 31, 2015 07:58 AM
nelsonht
Aug 30, 2015 06:01 AM
Rhett
Aug 28, 2015 11:30 PM
