stability control fail
Old May 2, 2010 | 11:56 AM
loudjag8's Avatar
Default stability control fail
Stability control fail pops up in the message center on my 99 xj8 once in a great while along with the ABS light. it doesnt seem to act any different but gets me wondering what the problem is..any idea?
Old May 2, 2010 | 06:41 PM
QuadManiac's Avatar
No Reduced Performance or Fail Safe message on the info display, and no Check Engine light?
Old May 2, 2010 | 07:18 PM
Gus's Avatar
Gus
Before you move on to the ABS control unit look at each wheel sensor and check the connectors.
If you have a 95xj6 I think I saw a tsb on the plugs.
Old May 2, 2010 | 11:04 PM
theusualsuspect's Avatar
had the same problem on my 2002 VDP and it can be a very expenisive or free mix. Hopefully you don't have to replace the ABS module. I actually had a ball joint and bushing replaced and while doing it they cleaned the sensors and 3k miles later the warnings have not come back. Hopefully its the same for you.
Old May 3, 2010 | 08:16 PM
loudjag8's Avatar
the check engine light didnt come on with it and no restriction on performance, the car acted as normal but with the message...it hasnt come on since last summer so i forgot about it but came up recently so i wondered if it was a prob...car stops just fine and brakes are quiet
Old May 4, 2010 | 07:14 PM
alckc's Avatar
as the other posts advise, check and clean the sensors first. i had the same problem. abs and stability control warning pops up now and then. after about 3 months it stayed on. i bought an abs module from ebay for 150. installed and bled the brakes - 1 hour job. problem fixed. called a couple of shops. they wanted anywhere from 1500 to 2400.
captbob73
Oct 24, 2015 05:49 PM
mrobinson
Sep 18, 2015 07:20 AM
'05 Gold XJ8L VDP
Sep 18, 2015 07:15 AM
Havigdort
Sep 13, 2015 04:42 AM
jaguarbill
Sep 5, 2015 11:43 AM
