Staggered Wheel Setup Question
Old May 27, 2020 | 10:39 PM
JXR's Avatar
JXR
Default Staggered Wheel Setup Question
Is the use of a staggered setup on an XJR R1 (i.e., 18 x 8.5 front, and 18 x 9.0 rear wheels) something necessary for the handling or balance of the car, or is it merely for the sake of appearance?
Jon
Old May 28, 2020 | 07:30 AM
Highhorse's Avatar
The stagger setup is used on the XKR, not the XJR...or at least on mine. My Pentas shoes are 255 all around.
Old May 28, 2020 | 07:36 AM
ericjansen's Avatar
I don't think anyone will know the real answer to your question .. but I guess it is / was a combination of things;
- Technical,
1. A rear wheel driven car,
2. A market moving to larger brakes / larger rims / wider rims,
3. Simply less technological advanced tires 20 years ago.
- Marketing,
1. A car in the later years of its lifespan, juiced up a bit for a better presentation.
For me personally, I am only interested in the aesthetics, and a 9" rear rim with some 275 tire is about perfect on a x308.
Old May 28, 2020 | 08:50 AM
JXR's Avatar
JXR
I did find this earlier thread with much helpful information:
https://www.jaguarforums.com/forum/x...up-not-204660/
I'm not sure why it didn't show up using the forum's search feature -- I was simply googling.
Jon
Old May 28, 2020 | 09:36 AM
Highhorse's Avatar
Jon
The site Search has a lot to be desired since an upgrade a couple years ago. I've lost threads and pics as many others have. I've found threads as you have, but when I try again on site again, ..no good.
Old May 28, 2020 | 09:40 AM
M. Stojanovic's Avatar
You will have no issues with this staggered setup. The handling (steering geometry) is only affected when using a different offset than the factory, especially on the front wheels. Small (say about 5 mm) deviations from the specified offset do not really matter. So, the staggered wheels are basically for show and somewhat better grip on the wider rear wheels. In the case of the combination of 8.5 and 9 in., the "stagger" is rather small and will not really be noticeable.
JXR
May 25, 2020 09:57 AM
Vegas_Jag
Apr 26, 2020 01:29 AM
Britrover
Dec 14, 2018 10:37 PM
tbsjaguar
Oct 7, 2012 04:15 AM
