Starting with a Headless Engine
Old Aug 13, 2010 | 07:44 PM
jaginblack's Avatar
Question Starting with a Headless Engine
Catchy title, eh?
I am now reassembling my engine after having the heads restored (following a timing chain/tensioner failure). My beautifully restored heads are back in place with new gaskets, torqued down, and the cams have been installed.
I am at the point of putting on all new chains, guides, and tensioners, and have run into a situation with the crankshaft setting plug: I cannot see any triangle indent on the drive plate and since my cams were off the position of the flats is no help.
When we rotate the crank, there only one spot where that plug will drop fully into place. Is that all I need to look for?
Some confirmation of that would be great before I start tightening everything down. Thanks.
Old Aug 13, 2010 | 08:28 PM
sparkenzap's Avatar
yes, the triangle is not on all engines- The hole with the slightly rounded side is the right one.
Old Aug 13, 2010 | 09:20 PM
jaginblack's Avatar
Thanks for that clue - it is really hard to see anything through the access hole. I guess I could get a finger in there and feel to see if it is a rounded hole.
Old Aug 16, 2010 | 08:14 AM
jaginblack's Avatar
Couldn't get a finger in to feel it, but evidently I had the right hole, as she purrs like a kitten. It was the only place where the plug would seat fully.
I know that sounds a bit suggestive, but I am talking about my XJ8L...
D.K
Dec 10, 2023 02:05 AM
tberg
Sep 7, 2015 07:32 AM
David Thompson
Sep 3, 2015 07:48 PM
XFR_Gold
Sep 2, 2015 12:24 PM
TC Johnson
Sep 2, 2015 09:30 AM
