starting issue
Old Mar 10, 2008 | 04:48 AM
FactoryJaguarTech's Avatar
Default RE: starting issue
does the dash light up when it is not starting?
If so, next time it does this, sit in car and lock it with remote. Then, unlock by pulling door lock rod. This will simulate someone breaking into car. Then insert key in ignition while alarm is on, turn key on and see if alarm goes off. Then turn key rest of way see if starts. Report back with your findings.
Also, look at the connector on the passeneger side behind the right shock. Has rubber boot on it. Make sure it istight.
Old Mar 10, 2008 | 05:57 PM
jag_genius's Avatar
also had battery megafuses melt or come loose causing intermittent no starts but everything lights up when ign on..
JarodL
Mar 7, 2024 01:39 AM
PMKimpton
Aug 3, 2019 08:22 PM
Raul Lara
Sep 14, 2015 07:31 PM
Jjscruggs1
Sep 3, 2015 07:46 PM
obwoodie
Sep 3, 2015 07:45 PM
