Steering Wheel Problem...
Old Dec 7, 2018 | 01:20 PM
omgimali's Avatar
Default Steering Wheel Problem...
Old Dec 7, 2018 | 02:46 PM
motorcarman's Avatar
The plastic 'reach' gear or steel threaded 'screw' is/are damaged.
I always just replaced the column complete when I worked at the dealer. There are no repair kits available that I am aware of. No individual parts for the column repair.
A salvage yard is likely you best option for a cost effective repair.
bob
Old Dec 7, 2018 | 03:34 PM
omgimali's Avatar
Old Dec 7, 2018 | 07:54 PM
The reach motor in your column works. You do not need a replacement motor.
The entire ebay column will work but you need to transfer the ignition lock assy.
bob
Old Dec 26, 2018 | 09:32 PM
Len Apcar's Avatar
Looks like your reach motor sometimes works and sometimes doesn't. I am not one to argue with motorcarman but years ago I bought a part from Coventry West Coventry West - Jaguar and Land Rover Parts that restored the reach motor's ability to move the column in and out. It was a tightly-wound spring part about four or five inches long that did the trick without replacing the reach motor. Not absolutely sure it is what you need but it is a reach motor fix. Glancing over the site now I dont see the part immediately, but you could give Coventry a call too and ask if they still sell them.
carzaddict
Aug 24, 2016 03:35 PM
bullittandy
Jul 10, 2016 02:31 PM
weisberg
Nov 4, 2014 08:46 PM
chupacabra
Jul 16, 2010 04:53 AM
vagearhead
Apr 29, 2009 05:39 PM
