Still cant keep my 2001 Jaguar XJ8 VDP running.
Old May 18, 2011 | 07:57 AM
Crownewourth's Avatar
Default Still cant keep my 2001 Jaguar XJ8 VDP running.
Morning all! To recap the situation some. Thanks to all of my mates here I was able to catch my tensioners before they became a real bother. So we replaced everything (tensioners/chains/water pump/thermostat etc..) All went well until we wanted to try the car out. The car starts fine...runs for a few minutes then cuts out. Then it is difficult to get started again. We changed the fuel pump relay thinking that was the culprit...didnt change a bloody thing...next we are heading to change the fuel filter and the fuel pump....I am looking for ideas of what else I should look at it...I did check the fuel switch cut off..that seems to be fine aswell. The VDP has 120k on it..this is the first issue it has ever given me aside from a thermostat issue. I am quite serious when I say this is the best damn car I have ever owned. Any input is always appreciated. I am simply at a loss now of what else I should be checking...thanks to my mates here...you are a clever bunch indeed! CHEERS!!!!
Old May 18, 2011 | 09:34 AM
sparkenzap's Avatar
Crownewourth:
I suggest you take a different approach. Instead of changing parts, diagnose the problem. As an example, you COULD buy about $200.00 worth of parts, spend 2 + hours on replacing the fuel pump and filter (if you are fast and lucky) OR buy a good fuel pressure test guage ( $55.00)with a 1 meter hose, connect it (5 minutes) and read if you have a steady 40 psi (2.7 bar) or so fuel pressure. Yu then know whether or not you have a fuel delivery problem, for sure, without doubt.
Other diagnosis is not as cheap nor as well defined, but fuel delivery is.
Good luck.
Old May 18, 2011 | 09:59 AM
Thanks Ross...I think we are headed in that direction actually..I had a question..do these cars have 2 fuel pumps ( I didnt think so) however it was posed to me by the mechanic that is helping me with the car...I dont mind changing the fuel pump actually..I just wondering if there is something else I should look at
Old May 18, 2011 | 10:57 AM
adembins's Avatar
Only the xjr/xkr have 2 fuel pumps.
Old May 18, 2011 | 04:13 PM
sparkenzap's Avatar
Crownewourth:
adembins is exactly right. No one stupid statement from a mechanic should impeach his work, but you have already learned now not to take the fellow's word as absolute. The XJ8 has one pump.
Check the fuel pressure. It is a trivial effort!
Old May 19, 2011 | 12:59 AM
QuadManiac's Avatar
Crownewourth: Check my suggestions in your newer post - should help you deal with the lack of 12V at the fuel pump fuse.
philwarner
Dec 6, 2021 07:13 AM
celticpiping
Sep 18, 2015 06:17 PM
bigw909
Aug 30, 2015 09:29 AM
dpappyp
Aug 27, 2015 06:31 AM
souldoubt
Aug 25, 2015 08:15 PM
