Strange valve clearance problem.
Old Jan 11, 2012 | 04:05 AM
Sean B's Avatar
do it like this....
Tap out a similar size metric, then use a short bolt with a copper sealing washer and plenty of threadlock.
Attached Thumbnails Strange valve clearance problem.-dscf5561.jpg   Strange valve clearance problem.-dscf5562.jpg
Old Jan 11, 2012 | 08:38 AM
xjrsteve's Avatar
Thanks Sir!
Old Jan 11, 2012 | 09:04 AM
Sean B's Avatar
Steve, don't forget to use a thin screwdriver with a blob of grease to pickup the swarf after tapping out the hole , you don't want bits of metal in the oil system. I guess you used a VVT head!
Old Jan 12, 2012 | 08:19 AM
xjrsteve's Avatar
Thanks Sean! Yes, as magnet is not "usable" for gathering the aluminium bits, I will use grease.
As I wrote earlier I got a VVT head, but I forgot about the VVT oil gallery. Thats a shame, so I will became a practiced front cover taker.
Old Jun 30, 2016 | 11:52 PM
lelledge's Avatar
Default Have same problem
Originally Posted by Sean B
Steve, as you have a spare car/engine, I'd suggest using another cylinder head. The original head can be fixed, but I don't know at what cost, and the other issue is warping, it may need skimming, and a number of valves/seats/guides replacing, not just one. It can get very expensive, quickly!!
To use the spare car's cylinder head we need to know if it's AJ26 (Model year?) and the model year of the project car's engine (AJ27?) Because there is one difference in the two cylinder heads, i.e. the cam position sensors. The 26 has one, the 27 has two, so, you might need to swap an intake camshaft.....
Omg, this is the same problem I am going with my 2000 Vanden Plas N/A
i took this photo, because I noticed something that seems odd to me..... is this the valve seat I am seeing? this photo was taken from the left side
Old Jul 1, 2016 | 05:30 AM
Addicted2boost's Avatar
The engine overheated causing that valve seat to drop. If the rods aren't knocking, then you need to pull the heads to send off to a machine shop. They'll determine if the heads are salvageable.
FrickenJag
Jun 16, 2025 02:15 PM
bamforp
Aug 14, 2024 05:36 PM
salP3082
Sep 25, 2015 05:07 PM
simo5555
Sep 9, 2015 06:22 AM
carelm
Sep 5, 2015 01:13 AM
