Sunroof buttons to show error codes
Old Aug 17, 2017 | 01:41 AM
Jetze Mellema's Avatar
Default Sunroof buttons to show error codes
I have an 2000 XJ8 with a sunroof and I recently discovered that I can use the buttons to display information on the dashboard. The close button shows the VIN, the open button displays errors (brake fluid low, etc.). This only works with the ignition key in the first position, in the other positions the roof will obviously open or close.
Does anyone know more about this feature? I never seen it documented somewhere.
Old Aug 17, 2017 | 02:21 AM
King Charles's Avatar
That's a new one on me, kind of wanting to go out & try mine @ 3 AM lol.
Old Aug 17, 2017 | 03:11 AM
Daim's Avatar
1st position means just in the lock or with aux on? My sunroof open and closes on 1 and 2 unless 1 is in your case just in the lock and not turned!?
Old Aug 17, 2017 | 03:38 AM
I mean the key in the lock position or even not in place at all. I'll see if I can make a video.
Edit:
Old Aug 17, 2017 | 05:44 AM
Daim's Avatar
This is interesting. Wonder is my 97 will do it...
Old Aug 17, 2017 | 05:48 AM
Daim's Avatar
Just checked... My 97 does not do this.
Old Aug 17, 2017 | 06:08 PM
Samilcar's Avatar
Strange. I just tried, my 1998 does not do that, either with the key in position 1 or out of the ignition.
Old Aug 17, 2017 | 11:42 PM
Don B's Avatar
Hi Jetze,
That is a very interesting feature! I just tried our '03 U.S.-spec XJ8 and it does not display the VIN or any flagged faults as yours does. I wonder if this was a dealer-selectable feature that could be enabled with IDS/WDS/SDD?
Thank you for bringing this to our attention!
Cheers,
Don
Old Aug 18, 2017 | 01:32 AM
larney's Avatar
Just tried mine. Nope just opens and closes. Tried other key positions. Still a nope.
Old Aug 18, 2017 | 10:32 AM
luc's Avatar
luc
same here on 01 XJR
Old Aug 22, 2017 | 07:10 AM
So I guess my car is unique then.
Old Aug 22, 2017 | 09:29 AM
motorcarman's Avatar
I tried both my XJ8s and neither does that.
I guess your car is UNIQUE!!!!!!!!!!!!!!
bob
Old Aug 22, 2017 | 12:25 PM
CharlzO's Avatar
'03 US-spec XJR and nothing on my end either. Was hoping to have a new trick to show off, but not meant to be.
