Sunroof drains
Old Oct 26, 2019 | 03:57 PM
Chairman6807's Avatar
Default Sunroof drains
I have a 99 VDP with a ruined headliner. I figure the sunroof drains are clogged. I have been told the drains are at each corner but where do they drain to? I want to be able to be sure I have them all clear before I replace the headliner.
Old Oct 26, 2019 | 04:35 PM
avern1's Avatar
Attached is a diagram of the drains. They go down the forward A pillar and the rear C pillar to the chassis.
File Type: doc
Old Oct 26, 2019 | 04:52 PM
I definitely appreciate it. Can you tell me where they drain to? In the fender wells?
Old Oct 26, 2019 | 08:10 PM
avern1's Avatar
They exit the body behind the wheel arch liners. You remove the front and rear arch liners and the front drains are at the rear of the wheel arch and the rear drains are at the front of the arch. Rubber hoses for cleaning it is easier to insert a small flexible wire from the arch liners to clear the drains. Normally the drains are clear and the problem is debris at the sunroof drain openings.
Old Oct 26, 2019 | 08:15 PM
Thank you!
curtis505
Aug 23, 2018 08:33 AM
jeffn
Apr 30, 2018 08:48 AM
melby
Dec 1, 2017 05:33 PM
susu
Jan 24, 2016 10:07 AM
AquaticEngineer
Nov 30, 2013 10:08 AM
