Supercharger belt fitting problem, '98 XJR
Old Apr 14, 2009 | 06:19 AM
tim_c's Avatar
Default Supercharger belt fitting problem, '98 XJR
I recently bought this Jaguar OEM supercharger belt and pulley kit for my '98 XJR
http://www.britishparts.co.uk/.sc/ms...ENSIONER%20KIT
I tried to fit it over the weekend. The pulley and tensioner fitted fine, but the new (double sided Jaguar) belt is too long, and the tensioner sits almost on it's maximum rest stop and rubs on another pulley (water pump or something) nut when fitted with the replacement belt, so would destroy the tensioner pulley.
As a workaround, I refitted the (Jaguar single sided OEM) belt which I had removed, and all is ok again... Albeit a bit squeaky!
Has anyone seen this before? The pulley only fits one way on it's new bracket, as does the tensioner (with it's 2 locating lugs). They cannot be fitted incorrectly. The belt routing is identical to how it came off...
The kit is suposedly modified, but the tensioner and pulley are pretty much identical, I can't see how they warrant a longer belt. The diameters of the pulleys are the same as the ones which came off, although the pulley wheel designs are slightly different.
I'm stumped Britishcarparts said they've had no issues before with that kit. If I send it back and they say it's ok, I get no refund...
Tim
Old Apr 14, 2009 | 02:01 PM
tim_c's Avatar
Well, the idler pully behind the SC belt tensioner was... shall we say... not done up. That would explain it. It's bolt was loose, and at an angle. And it's not one I touched!
All fixed now, the new belt fits, and the tensioner doesn't hit the bolt
toronadomike
Jan 22, 2026 10:13 PM
jdzubas
Oct 4, 2015 09:14 AM
jehart49
Sep 12, 2015 05:36 PM
alpecsa
Sep 7, 2015 11:55 AM
TC Johnson
Sep 2, 2015 09:30 AM
