Supercharger Duct Seal Q's?
Old Feb 8, 2015 | 05:43 PM
Tripa's Avatar
Question Supercharger Duct Seal Q's?
Hi guys. I have noticed some blow through from my supercharger duct seals, and after some reading i have come to believe this is a part that was suceptable to problems... I am also under the impression that a new version of the kit is available that solves the previous problems... my Q's:
1. Is this the upgraded newer version? Supercharger Duct Seal kit - BPK30357 | Jaguar XJ8 X308 - XJR, Jaguar XK8 - XKR | Jaguar | British Parts UK
2. Is there an easy way to install the kit?
3. will i need any extra parts? My mechanic tells me i should also buy a top plenum cover gasket seal because this will need to come off to install the new duct seals and plates...?
4. Does anyone know of a cheaper place to buy the kit? Im in Australia...
As always. Thanks for all your help!
Old Feb 9, 2015 | 06:32 AM
andrew lowe's Avatar
Yes, that is the upgraded kit.
The plenum seal is in the kit ( the big square gasket the bolts are in )
Its not a hard job
Old Feb 10, 2015 | 04:22 AM
Tripa's Avatar
Perfect. Just what I needed to hear. Thanks Andrew! Am i likely to find the part cheaper anywhere else? Anyone have any tips for sites I should check before purchasing from British Parts? The kit won't be in stock until end of Feb so I have time... Again, thanks for all help.
vwbusbits
Oct 13, 2015 03:43 AM
moff1959
Sep 26, 2015 05:35 PM
SD96XJ6L
Sep 25, 2015 10:53 PM
BSM
Sep 25, 2015 05:00 PM
