The switch to LEDs
Old Nov 28, 2021 | 07:59 AM
Reddevil's Avatar
Default The switch to LEDs
The transformation to better lighting is nearly complete. I chose SuperBright LEDs for the task. Other than the high mount stop light (which is crumbling apart, difficult to remove, and will likely be replaced), the job was straightforward. Door courtesy bulbs were an easy task, and shine on the ground much better:
The rear interior lights were a little tricky because the lenses are brittle, and tight space for large hands:
The maps lights required removing the overhead console, not difficult:
The boot lights were a little trickier because the bulb lenght is very short. Yhe first couple bulbs would not fit in the housing, but, I found a shorter bulb. The housings dont seem to click back into place, so I will use a little silicone to set them back in:
The license lamps were straightforward, and make a big difference:
The rear lights (brake/stop, turn, fog, running) were a challenge ( I didnt know how the fog lights worked). I used Canbus bulbs and still get "check rear lights" on display, but, I can live with that:
Old Nov 28, 2021 | 08:05 AM
Reddevil's Avatar
The pilot lights, up front, were a pain. The little arms you twist to remove just snapped off. Brittle pieces. So getting my hands in there was a challenge:
Side marker housings were brittle also :
I got LED fogs lights also, but, one didnt work (I even switched polarity), so Im waiting on replacements. When thise are in, I will post photos. I also purchased a new undershield because mine was missing.
I am pleased with the outcome.
Old Nov 28, 2021 | 09:12 AM
RA110623's Avatar
Banned
Looks good I have Philips led in the license plate lights 2 years still works fine . For high and low beam I use nineo and beam tech
Old Nov 28, 2021 | 09:47 AM
Reddevil's Avatar
Are the hi/lows led? Im having a hatd time finding ones that "lock" into the housing.
Old Nov 28, 2021 | 09:58 AM
RA110623's Avatar
Banned
Nothing did work I used lock tight glue gel
Old Nov 28, 2021 | 02:07 PM
Z07Brandon's Avatar
Don't people use e39 bmw bulb holders for the low and high beam hid&led retro fits? Looks good! Did the same to my car. Have the hid headlight kit sitting, waiting to be installed. But, need to get the proper holders. Easily one of my favorite mods to do on cars-upgrade the lighting.
Old Nov 28, 2021 | 02:37 PM
Reddevil's Avatar
not sure about the bmw holders, if they work or not. You are talking about the wire ones? I would like to know as well.
Old Nov 28, 2021 | 05:49 PM
Reddevil's Avatar
I found on here from a 7 year old post to use e46 adapters. Cant find it now. They were cheap enough, so I ordered some and will report back if they fit.
Old Nov 29, 2021 | 01:08 PM
vincent661983's Avatar
nice, Do you have link where you got all of the LEDs. I have the license plate LED bulb and every time I got it and a little too short in length and got loose.
Old Nov 29, 2021 | 01:23 PM
Reddevil's Avatar
https://www.superbrightleds.com/. I did have to bend the license plate lamp pins in slightly, to ensure a tighter fit. Just a little.
https://www.superbrightleds.com/more...2532&year=2001
Old Dec 1, 2021 | 02:37 PM
bfx308's Avatar
Hey guys, this looks amazing!
Can you maybe post a link to the LED you are using for each of these replacements? I'd love to do some of them (the easier ones!).
Thanks again for sharing!
Old Dec 1, 2021 | 03:15 PM
RA110623's Avatar
Banned
Get from rock auto
Old Dec 4, 2021 | 06:54 AM
Reddevil's Avatar
The BMW E46 adapters for hid/led headlamps will NOT work. So, I opted for higher wattage bulbs, Hella 100wtb, and put led driving/fog lamps in.
Old Dec 4, 2021 | 08:02 AM
RA110623's Avatar
Banned
Few drops of locktite glue gel works fine imo
Old Mar 5, 2022 | 10:02 PM
Z07Brandon's Avatar
These are H7 adapters. They sit mostly snug in the headlight itself. But my HID bulb doesn't slide all the way down. What am i doing wrong here?
I went through various old threads before asking.
Old Mar 6, 2022 | 04:37 AM
Reddevil's Avatar
I never did figure oit the headlamps. I just put bulbs in. Weird housings.
Old Mar 6, 2022 | 08:39 PM
pcolapacker's Avatar
Don't you get error message on the info screen under the speedo because they are pulling less wattage?
Old Mar 6, 2022 | 10:31 PM
Addicted2boost's Avatar
This may not look very professional from the backside of the headlamps but, it works very well. The same ones I installed about 3 years ago on my daughters XJR are still going good today. If you zoom in, you’ll notice that I used a zip tie. I had to remove each headlamp to successfully install the bulbs but, no glue was involved.
I know this isn’t a good sense of comparison but, they are a bright white bulb. I have them as a low and high beam. In this photo is pictured only the low beams and the inner little peanut bulb is a bright white. I can tell you that they’re plenty bright enough but I don’t get flashed from other drivers as if my high beams are on so it’s not too overwhelming.
VoRock8 R2 COB H7 8000LM Led Bulbs,High Beam Low Beam Conversion Kit, High Beam or Low Beam Bulbs, Fog Light, Replace Halogen Bulbs for Cars and Motorcycles, 6500K Xenon White, 1 Pair
Amazon Amazon
Old Mar 7, 2022 | 04:54 AM
Reddevil's Avatar
yes
viper1996
Dec 22, 2020 09:09 AM
Hex Type
Apr 21, 2020 05:49 AM
alynmurray
Nov 18, 2016 09:26 PM
n8ertot
Feb 21, 2016 08:05 PM
mkontos
Dec 24, 2014 02:48 PM
