Tail Lights out!!!
Old Aug 18, 2013 | 06:45 PM
mx5j8's Avatar
Default Tail Lights out!!!
Hi, 99 xj8l vandenplas, just discovered my taighlights are out as I watched my wife drive away. I had previously changed the relay in my battery compartment to no avail. Any suggestions?
Old Aug 18, 2013 | 06:49 PM
I've moved your post from Jaguar Forums Advice / Feedback & Suggestion Center section to X308 section. The Advice/Feedback section is for posts about the forum and not for technical questions.
Members here with the same model as you have will be able to help with the tail lights.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST section and post some info about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
Old Aug 18, 2013 | 07:53 PM
jimlombardi's Avatar
mx5J8
Forum member Avern1 resolved his no tail lights issue - quote:
"the hinge of the trunk on the passenger side is a wire bundle clipped to the hinge. I would start there before chasing modules. The wires fray and break in the bundle. Remove the wrappings, and examine each of the wires. I located the bad section by leaving the lights in the on position and then moving the wires flexing and pushing the individual wire until i found the area where the contact was lost.
I cut out the bad sections splice in and insulated new wires and all was "good as new"
Hope this is your problem and the fix will be easy."
Jim Lombardi
Old Aug 21, 2013 | 02:51 PM
mx5j8's Avatar
Thans Jim, your advice worked perfectly! I appreciate the time you took to research the problem. The lights were working within an hour! You saved me a lot of time and expense.
kj07xk
Dec 18, 2025 10:56 AM
tbird6
Aug 13, 2024 07:50 PM
SCMike
Sep 22, 2015 07:34 PM
billbjork
Sep 10, 2015 07:41 AM
motorhead69
Sep 9, 2015 10:04 AM
