Takeing car in for tranny fluid/filter change
Old Jul 17, 2017 | 03:39 AM
user 652867429824's Avatar
Banned
Default Takeing car in for tranny fluid/filter change
While I have my car in for a brake job I want to have the tranny/filter done. I know what the manual calls for (which is NLA) so what type or suggestions should I buy and what filter number.
Old Jul 17, 2017 | 04:47 AM
Daim's Avatar
There is a MANN filter kit available for BMW on Amazon. They are the same apart for the sump gasket which is also in the same kit...
Old Jul 17, 2017 | 09:56 PM
Banned
Thanks Daim, what type of fluid, I think I read somewhere that Valvoline Max Life is compatible
Old Jul 18, 2017 | 06:03 AM
King Charles's Avatar
Esso LT 71141/Mobile ATF LT 71141 or ZF Lifeguard 5 is what I was told & used in previous car.
Old Jul 18, 2017 | 07:10 AM
Daim's Avatar
I use cheap Mannol AG52. At around €2/liter it is cheap and does the same job well. BMW drivers praise it.
Old Jul 18, 2017 | 11:27 AM
Yes, I went w/ the Febi-Bilstein ATF on this car after hearing rave reviews from the local Jaguar shop, it was a bit cheaper to boot. Plan on draining & refilling in the coming weeks.
http://www.ebay.com/itm/FEBI-BILSTEI...-/112160220968
Old Jul 19, 2017 | 10:07 PM
wrd0225's Avatar
Default Transmission fluid and filter r & r
What was your cost?
Old Jul 19, 2017 | 10:45 PM
Originally Posted by wrd0225
What was your cost?
If directed @ me, I paid around 71$ for seven liters of Febi-Bilstein ATF, mind you I'm only doing a simple drain & refill .
Old Jul 19, 2017 | 11:31 PM
Banned
Not much more than I paid, but I bought 2 5ltr containers at $91.19 . was not too sure on them amount needed, but now you answered that question
Old Jul 19, 2017 | 11:49 PM
Yeah simple drain & refill takes up to 7, flush, filter etc. takes more.
