Tensioners and dodgy metal.
Old Jun 13, 2008 | 03:14 PM
JagtechOhio's Avatar
Default RE: Tensioners and dodgy metal.
An '03 XJ8 is an excellent car, with the prevous problem areas of timing chain tensioners and Nikasil plated engine bores corrected long before. Buy it and enjoy.
Old Jun 16, 2008 | 04:18 PM
Not clearcut by model year but by engine number. Later '01 onwardhas no Nikasil concerns, most if not all '02 will have upgraded tensioners. You're quite welocomed, and good hunting!
Old Jun 16, 2008 | 04:22 PM
Best available numbers :
Last Nikasil 00 08 18, stamped at LH side base of thermostat housing
First updated timing chain/ tensioner installation 01 08 13 (A. Voss, Belgium). Stamped on vertical rib, LH side of engine block. The VIN only helps if you can run it to find the engine number, and compare it with those dates.
mikiep
Dec 20, 2019 07:37 PM
pnwrs2000
Nov 17, 2015 04:04 AM
Jässe in Pälkäne
Oct 2, 2015 05:38 AM
millertic
Sep 30, 2015 08:11 PM
