Is there a way to install a XJ40 diff into X308 XJ8?
Old Jul 23, 2013 | 03:51 PM
MoscowLeaper's Avatar
Default Is there a way to install a XJ40 diff into X308 XJ8?
Hi, guys.
I have an option to get a FREE 3.77 diff with LSD from XJ40. I'm feeling a lack of power and a LSD is a quite handy option during russian winters.
Is it possible to fit it to mine XJ8? What mods are required?
Old Jul 24, 2013 | 10:11 AM
adam699's Avatar
Probably easier in an xj8 than an xjr computer wise. Search my threads. I have an old thread that walks you through the mechanicals. I have 3.58 with a loc on my car.
Old Jul 25, 2013 | 09:13 AM
Adam, what did you do with an offset of an older style diff? Did you just fitted a jurid coupling or driveshaft mods were required? Thanks.
Old Jul 26, 2013 | 01:43 PM
adam699's Avatar
You need the diff and the matching frontplate. The front plate needs to be modified to have exhaust hangers. Other than that it's a bolt in. The offset is minimal and requires no modification. Just make sure to get the diff with the right coupling for the jurrid. Some of the older ones have a 4 bolt flange that will not work. Swapping the flange from the x308 differential doesn't always work because of the spline count on the pinion gear.
Old Sep 17, 2015 | 01:22 PM
Teck4Jag's Avatar
the XJ40 diff is offset slightly and the 308 is centered if i remember correctly
FrickenJag
Jun 16, 2025 02:15 PM
dsnyder586
Dec 29, 2024 07:39 PM
vsol
Aug 29, 2018 09:46 PM
AtholC
Sep 9, 2015 09:07 PM
SteveSheldon
UK & Eire
Sep 8, 2015 11:22 AM
