Thermostat changed but got restricted performance after???
Old Sep 22, 2012 | 02:45 PM
RidenXj8's Avatar
Default Thermostat changed but got restricted performance after???
i literally just changed out my thermostat for what ever reason it was different then the factory therm. so i had to do slight fabrication to the therm. cover nothing major that would effect the seal but now i have a restricted performance light out of no where...i pulled the codes and these are the codes that popped can anyone tell me asap what they are p0455,p1000, p0327
Old Sep 22, 2012 | 03:26 PM
Sean B's Avatar
P1000 is a nothing to report code,
P0327 is knock sensor A Bank voltage low (bad connection or sensor)
P0455 is a fuel cap fault, try re-fitting it after clearing the codes and see if it comes back.
There's a how-to on replacing the knock sensors here,
https://www.jaguarforums.com/forum/x...ine-faq-45963/
Neither are coolant circuit related, but you could have missed connecting a knock sensor back up?
Hope this helps
Old Sep 22, 2012 | 03:33 PM
RidenXj8's Avatar
real random idk if something got wet wen i flushed out my radiator but i drove it tried a few places to get it checked came home posted these codes and then went back out started it up and all the codes were gone
aholbro1
Dec 29, 2024 06:46 PM
D.K
Dec 10, 2023 02:05 AM
Doug
Feb 27, 2019 01:31 AM
Aus V8S
Nov 13, 2015 11:01 AM
XFR_Gold
Sep 2, 2015 12:24 PM
