Third brake light
Old Oct 26, 2014 | 12:42 PM
Louis Pullara Jr's Avatar
Default Third brake light
On my 2001 XJR the third brake light came unglued from the rear windshield, what is the best glue to use in reattaching it. Thanks Lou
Old Oct 26, 2014 | 12:45 PM
Jhartz's Avatar
Use metal to plastic epoxy. Just a very small amount. Clean the glass, leave the metal tabs in place in the holder, just a little epoxy on the metal tabs and then press in place carefully. The plastic in the holder and in the cover is extremely fragile.replace any burnt out bulbs first. You will need to mix the epoxy and hold everything in place for a minute or so.
I found that double-sided tape and glue didn't work: would not handle the weight of the light fixture.
Last edited by Jhartz; Oct 26, 2014 at 12:49 PM. Reason: grammar and clearer description
Old Oct 26, 2014 | 12:50 PM
Jim thanks for the info. Lou
Old Oct 26, 2014 | 01:12 PM
Jhartz's Avatar
Hit the thanki button
H20boy
Dec 24, 2024 03:23 PM
mbergen
Oct 23, 2019 10:26 PM
PMKimpton
Aug 3, 2019 08:22 PM
KarimPA
Sep 12, 2015 08:15 AM
motorhead69
Sep 9, 2015 10:04 AM
