VVT Removal
Old Oct 17, 2014 | 04:00 PM
blackhonor9's Avatar
Default VVT Removal
Does anyone have instructions on how to remove the VVT actuator off of 2000 Jaguar XJ8? I am receiving code P1384 along with tapping when I press the accelator. I have changed the vvt solenoid already now I need to change the actuator. I am consider taking the VVT actuator off and leaving it off to see the the code and the tapping/clicking noise come back.
The two issue I see that can cause P1384 is VVT mechanical failure and low oil pressure. Could I get low oil pressure on one side and not the other?
Thanks in advance for all the help.
Old Oct 26, 2014 | 03:31 PM
coastaljag98's Avatar
Go up a weight in oil and the tapping may stop.
Old Oct 26, 2014 | 07:35 PM
test point's Avatar
. . . or try a can of RESTORE before the oil change. That will tell you if a heavier weight oil is going to solve the issue.
dsnyder586
Dec 29, 2024 07:39 PM
aholbro1
Dec 29, 2024 06:46 PM
mrsimpson
Sep 15, 2015 01:10 PM
SeanU
Sep 14, 2015 04:31 PM
doctordeuce
Sep 12, 2015 08:30 AM
