Throttle Body Connector Sourcing
Old Jul 4, 2018 | 08:56 PM
nd4spdlsc's Avatar
Default Throttle Body Connector Sourcing
Anyone know where I can get this connector body? It’s off the throttle body. It’s not in the Ford catalog. My research shows it is a Denso connector. Has anyone crossed a Toyota or Honda successfully?
Also, anyone know where I can get the pin insertion and release tool? The old brittle plastic is crumbling otherwise.
Old Jul 4, 2018 | 10:08 PM
M. Stojanovic's Avatar
You can get the connectors from the UK (Ebay):
TB 4 Pin - https://www.ebay.co.uk/itm/Toyota-20...AAAOSwFL9Ttne3
TB 3 Pin - https://www.ebay.co.uk/itm/Toyota-Le...oAAOSwOyJarQJ4
MAF 5 Pin - https://www.ebay.co.uk/itm/Toyota-5-...oAAOSw241Yb~zF
You don't need any special tool to remove the pins. Just pry out the white plastic locking insert and, using a small flat screwdriver, find a thin black plastic locking tab deeper inside next to each pin, pry/bend it gently away from the pin as you pull on the wire. To insert pins, remove and keep the white locking insert out, push each pin in until you hear a click and then push in the white insert.
Old Jul 4, 2018 | 10:29 PM
If you need gold plated terminals, you can get them here - https://www.ebay.com/itm/TD5-Engine-...sAAOSwA1FZ5LqL
Old Jul 5, 2018 | 01:32 AM
JagV8's Avatar
Wreckers will supply if they have the car.
Old Jul 5, 2018 | 02:12 PM
nd4spdlsc's Avatar
Thank you gents!! I've been searching for the connector body for 6 months!
xFyght
Oct 22, 2022 05:13 PM
car5car
Aug 12, 2019 06:33 PM
ultrablu
May 9, 2015 10:23 PM
Rkhlopin
Nov 11, 2014 08:37 PM
mzs_biteme
Mar 6, 2013 01:38 PM
