Throttle body prob
Old Mar 13, 2013 | 10:51 AM
steveinfrance's Avatar
Originally Posted by coastaljag98
Wouldn't I be getting o2 sensor codes if the cat was damaged. I have exhaust coming out and the thrift me body does the same thing if I stand at the hood and manually turn the cable with my hand.
Would a tb from my 98 work?
I can't quite cope with your thrift me body!
You wouldn't necessarily get codes if the cat was blocked.
Something is giving -ve fuel trims - the upstream O2 sensor is seeing too little O2 so it's trying to reduce fuel.
This either means a stuck injector (which would be unlikely since it is both banks) or back pressure.
I don't see how the TB would cause this but if you swap it we will see.
Old Mar 13, 2013 | 10:53 AM
coastaljag98's Avatar
Ok the 98 has a round black vacuum type canister on the top and the 99 does not. So can they still be swapped?
Old Mar 13, 2013 | 11:39 AM
dsnyder586's Avatar
ugh- don't think so.
Old Mar 13, 2013 | 11:44 AM
Gus's Avatar
Gus
Your other option is to have the one you have rebuilt. This is a link to my rebuild and the company. Are you sure it is a TB problem?
Old Mar 13, 2013 | 11:59 AM
I don't see how a naughty TB would affect those trims, Gus. What do you think?
Old Mar 13, 2013 | 12:28 PM
SuperSport's Avatar
Could a bad connection on the TPS throw those out?
Old Mar 13, 2013 | 01:34 PM
No, I don't think so. The MAF and the upstream O2 sensors do the stoichiometry.
The TB determines how much air goes through the MAF.
Does that make sense?
Old Mar 13, 2013 | 02:09 PM
  #28
SuperSport's Avatar
It totally makes sense, I just wondered if an intermittent connection could cause fuel to be sent erratically and cause bad readings. You are probably right though, just thinking out loud. Sometimes gets me into trouble.
Old Mar 13, 2013 | 02:47 PM
Gus's Avatar
Gus
I agree!
Old Mar 13, 2013 | 02:55 PM
  #30
Distraxi's Avatar
Can the problem be provoked by flooring it stationary against the brakes? If so, what do the instantaneous OBD readings say?
Also, does it misbehave all the way up the rev range or just in the midrange? For example if you gently bring it up to say 5000rpm in a low gear, then floor it, does it still stutter?
The first item in Jag's diagnostic flowchart for hesitation problems is EGR valve. A bad EGR valve can cause -ve LTFT too. Is your EGR known to be good? That flowchart's been posted somewhere here, by the way, probably by jlombardi.
You refer to the throttle flap not moving when you push the pedal, but say that's with the key off. That's normal. The flap is electrically controlled, not connected to the cable - it won't work with the ignition off.
Old Mar 13, 2013 | 04:31 PM
  #31
plums's Avatar
concentrate on this:
If I try to rev the engine up, I hear a sucking air noise like a "swoosh" and the engine shakes and acts like its starved for fuel
Old Mar 13, 2013 | 04:55 PM
  #32
Gus's Avatar
Gus
If you are trying to rev your engine with it in park the rev limiter will prevent it from going over 2000rpm.
Old Mar 13, 2013 | 06:11 PM
  #33
Okay good info guys. Where is the EGR located? Dummy me didn't turn the key on to get the flap open ughhh. You can gently bring it up and it won't hesitate but if I was wanting to pass a car and stomped it then it would kick and stutter. Make sense?
Old Mar 13, 2013 | 06:15 PM
  #34
Actually scratch the EGR valve I don't have a supercharged engine.
Old Mar 13, 2013 | 07:30 PM
  #35
Distraxi's Avatar
Vac leak's inconstent with -ve LTFT, but I can't think offhand what else would cause sucking noises.
Sorry, just assumed all US cars had them. Red herring.
Old Mar 13, 2013 | 09:05 PM
  #36
jimlombardi's Avatar
coastaljag98
Here is the throttle body part numbers and vin ranges:
Per the JEPC (parts catalog) here are the throttle body part#:
now C2A1470EK (C2A1470) - Vin Range from 812317 to 853925 (AJ26) $1189 new
now C2A1444 - Vin Range 853926 to F59525 (AJ27) without supercharger $1904 new
now C2A1445 - Vin Range F00035 to F59525 (AJ27) with supercharger $1720 new.
Jim Lombardi
Old Mar 13, 2013 | 09:16 PM
  #37
Thanks. I'm going to live with it til it gets worse. Ill get an eBay tb this summer for spare. I need to find my vac leak as I guess that's the sucking noise.
Old Mar 14, 2013 | 03:50 AM
  #38
You probably haven't got a vacuum leak, that would give +ve FTs (this is counter-intuitive I know, you'd think the extra air would lower the trims but the O2 sensor sees more O2 than it expects - O2 flow was measured in the MAFS BEFORE the leak - and bungs in more fuel to try for stoichiometry).
The only scenario involving a leak I can suggest is leak>too much fuel>cats damaged and what you're seeing now is back pressure from blown cats.
I don't know (apart from dismantling) how to check your cats.
Old Mar 14, 2013 | 07:41 AM
  #39
Yes makes no sense. The exhaust coming out te rear flows way to good or then to be damaged. I rechecked the live data and still getting the negatives tho. I just need to find this stutter problem.
Old Mar 14, 2013 | 08:52 AM
  #40
The other possibility is your MAFS screwed and is reporting a falsely high airflow so the ECM expects to put more fuel in than is actually needed (the opposite of a post MAFS vac leak).
Have you cleaned it?
Can you swap with the other car?
