Throttle pedal is not moving, but speed is changing.
Old Oct 1, 2014 | 03:19 AM
xjrsteve's Avatar
Default Throttle pedal is not moving, but speed is changing.
Please help me to start solving my problem, I did not find the answer by searching.
Sometimes when I drive with constant speed ( like 50-60 mph), and don't move my right feet, the car starts to accelerate and back. Like when I push the throttle pedal down a little, and back in between 1 sec. Usually it happen at 10 min. after cold starts. Later, and when the engine is warm, there is no problem.
I never have this problem when I accelerate, only at constant speed. I cleaned the MAF, and checked air leaks. Sometimes I got p0430, but not then, when the car is acting like wild horse.
Throttle?
Old Oct 2, 2014 | 12:46 AM
xjrsteve's Avatar
The engine pulls and back, pulls and back in short time, like when someone playing with throttle.
Old Oct 2, 2014 | 08:05 AM
vdpnyc's Avatar
No clue, but if since nobody answered you I will guess and suggest checking the spring under the accelerator pedal for sufficient tension, as well as the throttle-cable wire for slack/fraying or catching on something enroute to the throttle-body.
Also, if it is at highway speeds, check the full-load breather hose for air leaks (that would potentially do what you are describer as the air/fuel mix would be fluctuating when it shouldn't.)
Old Oct 2, 2014 | 09:09 AM
Jhartz's Avatar
And run a bottle of SeaFoam or Gumout's Best through a tank of gas: dirty injectors will cause a surging . . .
Old Oct 3, 2014 | 02:24 AM
xjrsteve's Avatar
Thank you guys! I checked air leaks, and the throttle's pedal, wire, spring.., but all are ok. Next week I will have a longer trip to try the seafoam.
Old Oct 22, 2014 | 08:50 AM
xjrsteve's Avatar
Maybe the problem has solved. I used three cans "degummer" fluid in the tank, and i did not got the problem for a week. Thanks for the idea!
Old Oct 22, 2014 | 09:33 AM
Jhartz's Avatar
Interesting what happens when the injectors fitfully spit instead a clean stream. Worst I ever saw was in my 88 325IS: idled roughly, surged (until North of 2000 rpm), but would clean up with Gumout or Lucas (I now think SeaFoam is best of breed).
silkcat
Jan 18, 2025 04:29 AM
PMKimpton
Aug 3, 2019 08:22 PM
hen555
Sep 7, 2015 11:13 PM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
