The tick persists...
Old Jul 15, 2019 | 10:14 AM
Melindasue Larrabee's Avatar
Default The tick persists...
The first thing I did on my 98 XJ8L was to replace the chains, tensioners, waterpump, spark plugs and refresh all fluids. A tick still remained that went away when driving only to return with each start up. Perhaps a shim was needed..my mechanic listened and number three seemed the one. But when he went in it was fine. He wanted to say a cam or crank sensor, however the car runs beautifully with no symptoms..just the tick at start up. Research on my part says possibly variable valve timing unit..but I dont know anything about them to say so. Can someone explain how they work..or give me another idea..thoughts appreciated.
Old Jul 15, 2019 | 10:58 AM
Jhartz's Avatar
Most likely fuel injector: add some fuel system cleaner and see if that helps. And enjoy driving it if it is running well.
Old Jul 15, 2019 | 11:04 AM
I have seen residue left on plugs from most of them..do you have a favorite to suggest? And yes...7,000mi of pure enjoyment so far with a 2500mi trip coming soon...
Old Jul 15, 2019 | 03:03 PM
Jhartz's Avatar
BG 44; Sea Foam; Gumout's most expensive
Old Jul 15, 2019 | 11:10 PM
King Charles's Avatar
+1 for BG44 !
David F.
May 5, 2019 12:23 PM
buddhaboy
Nov 29, 2017 09:15 PM
Pristine97XK8Convertible
Feb 23, 2014 11:10 AM
H20boy
Nov 4, 2013 10:07 AM
guzzi svt
Feb 1, 2012 05:09 PM
