Ticking noise after timing chain tensioners repair
Old May 11, 2011 | 03:42 AM
plums's Avatar
read post #6 in the thread below and see if it applies:
https://www.jaguarforums.com/forum/j...lt-help-54420/
Old May 11, 2011 | 03:55 AM
Dan R's Avatar
Originally Posted by MN JAG
Well guys-I did change the oil to 20-50 W and added restore and it was quiet for a bit. Shut the car off, waited a few mins and started up, nice quiet engine. About 20 mins later I started the car and bang its back, give it some gas a it goes away...
It appears to all be coiming from the rights side or passenger side.
I'm thinking that since this a "spare" car I going to tear into the engine check the chain guides and maybe as long as I'm in there change the chains... What the heck, at least it would be fun.
Anyone care to talk me out of it????
Considering the relative complexity of these engines a little bit of ticking is probably OK. The secondaries are replaced. Let sleeping dogs lie.
And replace the 20w/50 with 10w/40 before the MN winter!
Old May 11, 2011 | 07:10 AM
JimmyL's Avatar
Well, let us know what you find. It would be nice to have the luxury of being able to take your time and work on it instead of needing it to get to work and back every stinking day.
Old May 11, 2011 | 07:46 PM
MN JAG's Avatar
When when I bought the tensioners it did come with shorter bolts.... But I better check. That would be funny, tear it all down to find out it was as simple as a bolt(s) that was just a bit too long... I think it was as tight of a seal as you can get but I better check.
Stay tuned!
Old May 11, 2011 | 07:49 PM
MN JAG's Avatar
She usually sit in the warm garage and I drive another car, I love the ride but these roads..... When let's just say that they should never sell anything but a plow truck in this state!
Old May 11, 2011 | 08:08 PM
semyr19's Avatar
Does any one know of a good way to hold the crankshaft while you loosen the pully bolt?
Old Mar 3, 2015 | 01:42 AM
jonpalley's Avatar
Hi MN JAG,
Did you get the ticking/rattle figured out?
SD96XJ6L
Jan 12, 2022 04:30 AM
PMKimpton
Aug 3, 2019 08:22 PM
Sprayall
Sep 3, 2015 07:49 PM
KarimPA
Sep 3, 2015 07:32 PM
innzane
Sep 2, 2015 10:08 AM
