Ticking sound XJ8
Old Aug 7, 2018 | 07:05 AM
L.cd's Avatar
Default Ticking sound XJ8
Hi guys,
I have a jaguar xj8 1998. When i start the car i hear a ticking sound in the engine. If i rev the car a bit then the sound stops. Do you have any ideas what that might be? is that serious?
Thank you!
Old Aug 7, 2018 | 07:19 AM
Carnival Kid's Avatar
Does the ticking sound go away after a few minutes, or when the engine is fully warmed up?
Old Aug 7, 2018 | 08:11 AM
motorcarman's Avatar
Timing chain 'slap' at idle?????
bob
Old Aug 7, 2018 | 06:48 PM
deancantrell's Avatar
My “98” does the same thing. I believe it may be the variable valve timing solenoid. Some suggest that using a heavier engine oil solves the ticking at startup, but as I understand, it is not serious.
Old Aug 7, 2018 | 07:42 PM
Timing chain 'slap' at idle?????bob
Difficult to diagnose without actually hearing the noise, but I'm thinking "ticking" is more likely a cold cam/bucket noise, or maybe a VVT noise, than a timing chain slap, which I'm thinking would be more of a "clatter" than a "ticking". The timing cover tends to amplify noise, so that also would be a determining factor if the noise seemed to be emanating from there,............ "being there" and able to hear the sound would help a lot.
I would try a higher viscosity oil (I use 10w-40 GTX as a matter of course) which may help if it is a VVT problem. Not sure if that would help with a tappet problem.....maybe? And if the tensioners/chains have not been replaced yet, I would definitely put that on my bucket list.
If the "ticking" goes away after just a few minutes after start-up, I wouldn't be too concerned. I would do an oil change with a 10w-40W and see if that made any difference.
Will be interested to hear what transpires L.cd.
Old Aug 7, 2018 | 08:02 PM
Z07Brandon's Avatar
Agreed
Old Aug 8, 2018 | 12:07 PM
Brooklyn's Avatar
Default 2003 XJ8 308 ticking
Hi,
Saw this thread. A car I checked out has a similar issue.
I attached a video with the clicking noise. The car should have the aluminum tensioner being that it is an 03.
Any help would be appreciated.
Thanks,
File Type: mov
jagxkrtoofast
Jan 27, 2015 03:26 PM
Xcitmt
Dec 10, 2010 09:42 PM
hottienamedscottie
Apr 17, 2009 08:41 PM
alckc
Jul 14, 2008 05:00 PM
JagMan
Feb 25, 2008 10:23 AM
