Timing Chain list of Parts Please!
Old Mar 23, 2012 | 09:13 PM
travolson's Avatar
Default Timing Chain list of Parts Please!
OK, Iv'e manned up enough meat of my bones to take on the Timing Chain Challenge, the challenge of sweat, grueling agonizing train of thought, and sore fingers. My question now is, what do I need? Here is a list of what I think Ill need.
-cam locking tools
-4 METAL tensioners
-obviosly I have the socket and ratchet asortment
-maybe a new water pump
-deffinetly a new thermostat
-But do I need new chains since I've seen other member only replace the tensioners and guides
-and guides
This list I am aware will be costly, but much less costly than having Sir. Jeremy Sheffield of Manchester to do this for me for 22802587 pounds and 2 shillings. Or in the US (Im American)2582539782537892530789253978 worthless dollars. Little joke to lighten my stress as Im only 17 doing this job on the weekend.
Old Mar 24, 2012 | 12:42 PM
chernobee's Avatar
hey on the website called jagbits there is a kit i think it was $850 and had everything you need to do the job, minus the guides they were another $30-ish. If you didnt order from there at least you could view the list of parts.
Old Mar 24, 2012 | 12:49 PM
motorcarman's Avatar
The cooling system does not have to be drained to replace the timing chains/tensioners.
The job might be a little easier with the pump out of the way but not necessary.
If you do one side at a time, you do not need 2 cam lock tools.
Crank lock tool????
bob gauff
Old Mar 24, 2012 | 02:09 PM
jimlombardi's Avatar
Hi
Christopher's Foreign Car Parts -
JAGUAR V8 1997-01 COMPLETE TIMING CHAIN KIT, EVERYTHING
*http://stores.christophersforeigncarparts.com/** *-strse-100/Jaguar-tensioner%2C-Jaguar-timing/Detail.bok*
Complete Kit Upper & Lower Chains, Tensioners, Guides, Blades, Cam (Valve) Cover Gaskets, Spark Plug Seals, VVT Seals, Front Crankshaft Oil Seal & Front Timing Chain Cover Gaskets Total price $649.
Posted on their website -
THIS IS A COMPLETE TIMING CHAIN KIT,EVERYTHING YOU NEED
ALL 4 CHAINS
ALL 4 TENSIONERS
INCLUDING THE IMPROVED METAL CHAIN TENSIONERS
4 LONGER BOLTS FOR THE UPPER METAL TENSIONERS
ALL 4 NEW METAL DESIGN CHAIN GUIDE SLIDES
VALVE COVER GASKETS
SPARK PLUG SEALS & VVT SEALS
FRONT CRANKSHAFT OIL SEAL & FRONT TIMING CHAIN COVER GASKETS
I purchased this kit last year for our 2001 XJ8.
Jim Lombardi
Old Mar 25, 2012 | 08:49 AM
travolson's Avatar
Well thanks guys, luckily there is a man down the street from me I met just yesterday and he'll let me borrow all of his Jaguar special tools!!!!! He owns 11 Jaguars so he will deffinitly be at the top of my list for maintenance aids.
----and what is the deal by only working on 1 bank at a time and need using cam lockers?
Old Mar 25, 2012 | 09:34 AM
Hi travolson
You can buy the metal thermostat tower kit ($ 75.95 - tower & thermostat) and the water pump ($ 76.95 - ask if the gasket comes with the pump) at Welsh Enterprises:
Welsh Enterprises - New Jaguar Parts, Used Jaguar Parts and Accessories - XK120 - XK140 - XK150 - E-Type - MK - XJ6 - XJ8 - XJ - XK8 - XK - XJS - S-Type - X-Type - XF
Also there is a great DIY on your Tensioner project with step by step instructions and photos:
Tmingi chain and tensioner replacement
Jim Lombardi
xjrjag
Nov 27, 2025 09:16 AM
lobsterD90
Nov 12, 2022 09:51 PM
Bcrary3
Sep 12, 2015 08:43 AM
David Mason
Sep 3, 2015 03:17 AM
Bcrary3
Aug 31, 2015 11:29 AM
