Timing Chain / Tensioner Tool Kits : Suggestions?
Old Oct 28, 2013 | 06:28 PM
Platinum XJR's Avatar
Default Timing Chain / Tensioner Tool Kits : Suggestions?
Anybody know of a better deal on a set of timing chain / tensioner tools than these?
First Set
$186.00 shipped.
Second Set
$187.00 shipped.
These are the two best prices that I could find.
They both look to be the same.
I know I can rent a set, but owning my own set would allow me to take my time and not have to worry about returning anything.
Also, when I am done, I could just sell the set (or keep it for another Jaguar or a Range Rover).
Suggestions, ideas, comments?
Stewart
Old Oct 28, 2013 | 06:50 PM
Sean B's Avatar
Always nice to buy the right stuff, you can always move it onto the next V8 owner. Either will do. I use SPX but that's what the factory use and a bit more expensive.
Home: SPX Europe tool catalog
Do you plan on just the uppers or lowers too? guides and chains as well?
Old Oct 28, 2013 | 06:54 PM
Sean, I plan on replacing EVERYTHING I can while I am in there.
Upper and lower tensioners, guides, and chains.
I only want to do this ONCE
Stewart
p.s. Thanks for the info.
Old Oct 29, 2013 | 05:26 AM
Sean B's Avatar
Stewart - I didn't see the crank pulley removal tool, a normal pulley puller isn't really the tool for this job, you might need the crank pulley tool from SPX it makes this job easy, it's on very tight. Once this is removed you can pull the timing cover and set to work.
Old Oct 29, 2013 | 03:45 PM
Thank you Sean!
SD96XJ6L
Jan 12, 2022 04:30 AM
Sprayall
May 30, 2021 08:13 AM
Sprayall
Sep 3, 2015 07:49 PM
Chet Ramnarain (bozzner)
Sep 3, 2015 12:21 PM
OkieTim
Sep 2, 2015 12:48 PM
