torque converter bolts?
Old Jan 7, 2014 | 08:05 PM
Ericbilt25's Avatar
Default torque converter bolts?
Is there a special tool to remove the torque converter bolts from the x308 xjr? This is the only thing that's holding me back from pulling the engine out.
Old Jan 8, 2014 | 01:00 AM
XKRacer's Avatar
No special tool however I have a feeling they are a 12 pointed head, just use a 12 sided socket just don't quote me on it
Old Jan 8, 2014 | 03:24 PM
Ericbilt25's Avatar
It's a bit strange. The bolts appear only through the starter housing hole and nothing below. It's bolted on opposite side compared to my 97 xjr where as the bottom cover comes off and the bolts are visible to get your tool inside.
Old Jan 8, 2014 | 03:28 PM
Ericbilt25's Avatar
I found this thread & I may be blind, but i don't recall finding a plate to remove to get to the bolts. https://www.jaguarforums.com/forum/x...s21-faq-57639/
Old Jan 8, 2014 | 06:08 PM
avt007's Avatar
I removed mine easily by pulling a rubber cover off the bottom of the trans mission bell housing. No special tool just a socket, and it came out easily. Definitely not 12 point.
Check out step 25 of the Mercedes transmission removal pdf.
Old Jan 11, 2014 | 02:02 PM
avt007's Avatar
Does this help?
Old Jan 12, 2014 | 10:33 AM
Ericbilt25's Avatar
Originally Posted by avt007
Does this help?
Thank you.
aholbro1
Dec 29, 2024 06:46 PM
Dickie_L_J_O
Sep 13, 2015 07:44 AM
sadepol01
Sep 11, 2015 05:26 AM
iownme
Sep 11, 2015 02:57 AM
jaggermang
Sep 8, 2015 07:07 PM
