Trans too Hot/Failsafe Mode
Old Aug 29, 2016 | 09:55 AM
XJDanny's Avatar
Default Trans too Hot/Failsafe Mode
Hello Friends,
I have had my 2002 XJR give me this message three times in two years. It has 71,000 miles. After the first time, I replaced the trans fluid and thought the problem went away. But looking back, I now realize it's only a problem when it's hot outside.
Here are the specifics:
*It happens only when it's hot outside, like over 90 degrees.
*It has been parked for between 20 minutes to three hours after driving and is sitting in the hot sun.
*The car won't start. It just cranks and I get the "Trans too Hot" message.
*When I put it in neutral, it starts easily. The amber light comes on and the message on the dash rotates between "Trans too Hot" and "Failsafe."
*When I put it in drive, the messages stay on until I begin driving away. They immediately go away and never come back. The car drives normally.
Any advice would be appreciated. Thank you!
Old Aug 29, 2016 | 10:01 AM
plums's Avatar
Is the tranny properly filled?
I've had it happen twice. Both times in the rain.
Turn it off, start again message is gone.
In my case I figure it is the connector at the right front
corner of the transmission near the starter that is known
to fail. Easily replaced and cheap from a Mercedes dealer
with the upgraded revised part.
Old Aug 29, 2016 | 08:38 PM
Shotimer's Avatar
Happened to me once, @ 62k, after it had been parked ALL day.
I replaced the connector with a new one. When I took the old one out it was full of trans fluid along with the plug - cleaned the plug out real good, not a problem since.
XJDanny - if your connector is original, that's the problem.
Old Aug 29, 2016 | 09:54 PM
XJDanny's Avatar
Thank you both for the advice on the connector. Does the connector have a specific name or number? I've never replaced mine and if it's inexpensive, I'll order one from a Mercedes dealer. I would guess mine is original.
Old Aug 29, 2016 | 10:20 PM
plums's Avatar
Don't really know the name but most Merc parts guys are
familiar with the part.
To them, the tranny is a 722.6. Chrysler dealers will also have it
and call the tranny a NAG-1.
Should be $30?
You do need to replace it because a leaking bush lets tranny fluid
climb the wiring harness and soak the TCM. Then you are in for
much more money.
So how come I still have mine? Dunno
Travis O'Gallagher
Apr 3, 2016 02:49 PM
mark campbell
Mar 28, 2016 11:30 PM
Exterior
Aug 16, 2009 11:10 AM
Oct 21, 2006 10:17 PM
Oct 4, 2006 05:38 PM
