transmission ?
Old Mar 31, 2010 | 01:43 PM
johnny13's Avatar
Question transmission ?
my 98 vdp keeps going into transmission fault, what did i do to cause that and what can i do to make it go back to normal, please any info with this problem would be great.
Old Apr 1, 2010 | 06:01 AM
test point's Avatar
Are you getting a CEL? Any codes?
About the only thing to do is change the transmission fluid and hope for the best. These transmissions have a failure rate somewhat higher than desireable.
Check the discussions under 'Transmissions' at the XK8/R FAQ sticky:
https://www.jaguarforums.com/forum/s...ad.php?t=29800
Old Apr 1, 2010 | 07:31 AM
johnny13's Avatar
Im going to take the car to get it diagnose today, Im not sure what CEL means, somebody else told me to check the fluid, i know i have to do that directly through the transmission in other words no dip stick, i was wondering does the car need to be lifted up all around to give you a better idea how much fluid it has or just lift the side i need. thanks for the info.
Old Apr 1, 2010 | 08:05 AM
Leedsman's Avatar
"These transmissions have a failure rate somewhat higher than desireable" is said by contributor Test Point. Now there's a british-style understatement if I ever heard one.
Leedsman.
Poet
Feb 7, 2025 02:18 PM
Marka
22
Sep 11, 2016 12:09 AM
dmatthewman
Sep 30, 2015 10:10 AM
Old_Doc
Sep 29, 2015 03:43 PM
