Transmission Oil Inquiry
Old Nov 21, 2016 | 03:48 PM
Muhammad Umer's Avatar
Default Transmission Oil Inquiry
Hi,
i am on 81000 kilometers on my XJR, and i was wondering when to change the transmission oil and filter, i read somewhere that the xjr has G tronics gear, any advice, also i dont have the manual, i bought it recently with no service history. thanks in advance.
Old Nov 21, 2016 | 05:12 PM
CharlzO's Avatar
The XJR transmission is the "set for life" version. That said, I would be looking more around the 200,000 km mark to be a good mid-life point. At 81k km, it's barely broken in, so unless you are experiencing issues with it, I wouldn't bother changing it just yet.
Old Nov 21, 2016 | 09:04 PM
motorcarman's Avatar
The Mercedes Gearbox is easy to service. Look for 722.6, NAG1 or 5A580 gearbox for service info.
A fluid/filter change is always a good idea if the fluid appears dark or smells 'off'.
bob
Old Nov 21, 2016 | 10:58 PM
Mark SF's Avatar
The transmission was originally sold as sealed for life. However, over the years Mercedes has changed their service interval twice. The first time, it was for one change at 40k miles, then no more. Now they recommend a change every 40k miles.
My XJR had the change done at 58k at a dealership, and I then did it again at 135k miles. The fluid colour itself was not too bad, but there was a thick layer of black sludge at the bottom of the pan.
If yours never got the 40k change, it is due now.
Old Nov 22, 2016 | 01:57 AM
Stu 1986's Avatar
I'd be changing it for piece of mind if nothing else.
Old Nov 23, 2016 | 10:12 PM
Vector's Avatar
Don't forget the "sealed for life" to the manufacturer means "good until the warranty runs out."
After that, it is not THEIR problem.
Change it every 50K miles or so and do the filter every 100K and you should be fine.
The XJR Merc tranny is very easy to service since it has a drain plug, not so easy on the XJ8.
You do need to buy or make a tranny dipstick, cheap on the 'bay, about $10 or less now. The car doesn't come with one.
Vector
