tricks on supercharged radiator replacement
Old Dec 21, 2022 | 09:53 PM
Quadcammer's Avatar
Default tricks on supercharged radiator replacement
Howdy all. Im doing my 4.2 crank pulley install an noticed a bit of the green crust on both my bleed hoses to the intercooler and around the bottom edge of the radiator.
I have a good used rad on the way but the jag workshop manual is not super clear.
Im guessing remove the coolant hoses, tranny cooler hoses, top panel, remove any bolt connections for ps cooler and ic he, and then out it comes? Any issues with access or tricks?
Old Dec 22, 2022 | 05:36 AM
Addicted2boost's Avatar
You remove it from the bottom without having to pull the radiator and condenser out is what I remember. Remove the grill and lower splash shield. Be very patient with the plastic pipes.
Old Dec 22, 2022 | 10:56 AM
Quadcammer's Avatar
so removing the radiator was no big deal. 10 T40s on the top panel, tranny cooler lines, all major and vent hoses and then slowly wiggle it up and out, being very careful with the a/c and powersteering cooler lines. Took maybe 15 minutes.
Old Dec 22, 2022 | 11:45 AM
scottjh9's Avatar
Check your sway bar bushes while rad is out. Very easy job with it out. The oil cooler lines are pretty open i think also
Old Dec 22, 2022 | 12:20 PM
Quadcammer's Avatar
done already, thanks. At the end of this car there may be about 5 mechanical parts on this car that haven't been replaced.
Old Dec 22, 2022 | 12:57 PM
RandyS's Avatar
This reminds me of a '69 SS Camaro that I felt the same way about. The good
thing about it is...you really know your car!
Old Dec 22, 2022 | 12:58 PM
scottjh9's Avatar
fantastic. I have an 06 str and have those front sways left and 2 heater hoses. Both in great shape still. A lot of work but oh so satisfying and well worth it. Even rebuilt the charger while it was off for the valley hoses. I could not own this car without doing my own work and the knowledge on the forum
St. Stephen
Mar 21, 2022 09:48 AM
Shahar Alon
Sep 6, 2018 03:46 AM
new mexico
May 22, 2017 09:43 PM
Eaa
Nov 11, 2012 07:21 PM
