Trim settings
Old Jun 15, 2019 | 05:19 PM
Dutchy's Avatar
Default Trim settings
Hi all my car is running fine had to replace the coolant tank had not a split on the weld joint but on the engine side, all done
to check the trim what is the procedure by that I mean
should it be at a certain revs, should it be under load either by acceleration or up a hill, is it a certain speed.
what is the benchmark for testing if there is one?
Old Jun 15, 2019 | 07:10 PM
RJ237's Avatar
At idle no load and 2500 rpm under load.
Old Jun 15, 2019 | 07:47 PM
Dutchy's Avatar
thank you
so if I hold the brake peddle and rev to 2500 would that do?
Old Jun 16, 2019 | 03:51 PM
JagV8's Avatar
Yes, fine.
2002XK8Orlando
Jul 18, 2010 01:29 AM
jimmy
Jan 27, 2010 09:00 AM
Elowan
Jul 10, 2009 06:56 PM
biobabe
Apr 25, 2008 10:08 PM
