Trouble Codes XJ8
Old Jan 14, 2014 | 06:30 PM
mara52's Avatar
Default Trouble Codes XJ8
What do the following codes mean for a 2000 XJ8:
0352, 1316, 1313, 0302
What should I do to correct the intermittent problem of the car running with the RESTRICTED PERFORMANCE light showing?
Old Jan 14, 2014 | 06:33 PM
Gus's Avatar
Gus
Look up your codes on this chart then ask your questions.
Link http://www.jagrepair.com/images/Auto...7_ECM_2000.pdf
Old Jan 14, 2014 | 07:21 PM
mara52,
I've moved your question from General Tech Help to X308 forum. This is the place to post questions about your model.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some info about yourself and your vehicle for all members to see.
In return you'll get a proper welcome and some useful advice about posting to the forum.
Old Jan 15, 2014 | 04:52 AM
kyle04's Avatar
In a nutshell you have a faulty coil pack on cylinder #2 (right hand A bank - USA passengers side, 2nd cylinder from front of engine).
The "0352" refers to the specific coil pack (035x is the code, where x is the cylinder number).
0302 = misfire cylinder #2
1316 / 1313 = injector misfire - you get this when a coil pack goes bad.
To double check :
- clear codes with your reader
- swap #1 and #2 coil packs around
- fire up and compare resulting codes. you should now have 0301 and 0351 which would confirm the coil pack.
AndyP
Jpav27
Jul 31, 2022 06:43 AM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
jagfool
Sep 14, 2015 07:50 PM
corysansburn
Sep 10, 2015 06:15 AM
TexasCat
Sep 8, 2015 04:36 AM
