Trunk will not unlock
Old Apr 24, 2013 | 01:03 AM
YoungRobertL's Avatar
Default Trunk will not unlock
All of a sudden, the trunk will not unlock with the key. The buttons have not worked since I pushed the "Valet" button. I have been unable to "un-valet" the system, trying most everything I was told. Perhaps I need a "weird" solution? But really, all I want to do is get into the trunk!
'98 XJ8 - 145k miles
Old Apr 24, 2013 | 08:26 PM
Lear45's Avatar
Try some WD 40 on the trunk key lock. You can remove the license plate and open the
latch with a long screw driver. I think I used the upper right slot to do it. There are old threads that talk about it as well. Don't remove the back seat to gain access, that does not work. Once the trunk is open, you can fix the electric latch and the mechanical key
latch. They have 2 separate arms. There are some plastic clips that break easily. If broken, the trunk won't open.
Old Apr 25, 2013 | 12:52 PM
Thanks for the tips...I will give it a try & let you know how it worked...
philwarner
28
Jul 11, 2017 10:21 AM
jluckcuck
Nov 6, 2015 07:49 AM
Bigvettefreak
Sep 28, 2015 03:03 AM
jessejamestw23
Sep 26, 2015 03:57 PM
