Ultimate pedals, brake & accel pedal covers
Old Apr 22, 2022 | 11:00 AM
Probesport's Avatar
Default Ultimate pedals, brake & accel pedal covers
I recently received a pedal set from Ultimate Pedals, the install was easy and they look fantastic. The accel pedal is flat and really could use a but if a curve to fit as well as it could so I took it to a body dolly and slowly dropped in a curve which worked out perfectly.
Install is easy,
  1. Put something down to catch shavings from drilling, I used paper towel
  2. Remove rubber cover from brake
  3. Clean and dry pedals, cover in tape to aid in marking
  4. Align pedal covers and pedal, mark through hole in pedal cover
  5. Use center punch on markings, remove tape
  6. Punch and drill a pilot hole in both pedals
  7. Since accel is plastic and doesn't have a flat back, I used the supplied standard screws to attach accel pedal
  8. Drill out brake pedal hole to fit hardware, supplied machine screw, washer, and locknut
  9. Install brake pedal
  10. Clean up and done.
Richouser
Apr 1, 2021 08:51 PM
stmcknig
Jan 1, 2017 10:10 PM
John_H555
XK120 XK140 XK150
Nov 9, 2013 09:46 AM
DB6
Jun 21, 2011 11:21 AM
