Unable to open passenger door.
Old May 30, 2012 | 05:17 PM
mv33rs's Avatar
Default Unable to open passenger door.
Hello there,
I have this issue since I got it, the left passenger door does not open. It has a loose handle from the outside and the inside handle doesnt work. I want to take a look inside however I'm not able to do that without opening the door first right? Any suggestions?
Old May 30, 2012 | 05:26 PM
OldMike's Avatar
What a quandary. Have you tried using the key in the outside lock and then pull on the inside handle? How about pulling up on the lock stem, pulling out on the inside handle and giving the door a nudge with your shoulder? Other than getting the door open first, I'm not sure how you're going to access the inside of the door for the repair. Maybe someone else has a better suggestion.
Old Jun 3, 2012 | 12:59 AM
vincent661983's Avatar
the cable inside is broken, I just had it fixed
99xk8guy
Sep 29, 2025 10:51 PM
aholbro1
Dec 29, 2024 06:46 PM
kevinl
Oct 31, 2019 06:15 PM
DuhCar
Sep 11, 2015 10:58 AM
avern1
Sep 8, 2015 06:25 PM
