under engine pan on xj8
Subscribe
Nov 15, 2008 | 04:24 PM
can you operate the car without it,the engine pan? Is it necessary. Not the oil pan, the cover under the engine, the one the oil change people removed in order to change the oil.
Reply 0
Nov 15, 2008 | 04:34 PM
RE: under engine pan on xj8
You can, but I would not recommend it. It is called the under cover.
Reply 0
Nov 15, 2008 | 04:51 PM
Can you operate xj8 without the bottom engine cover under the car,is it necessary. Qil change charge to remove it.
Reply 0
Nov 15, 2008 | 04:53 PM
why not,thank you
Reply 0
Nov 16, 2008 | 05:17 PM
Mainly it is there for aerodynamics, but also helps keep the under engine clean and protects that area from road debris doing any damage.
Reply 0
Nov 16, 2008 | 10:10 PM
Thank you HLgeorge for that infornmation.
Reply 0
Nov 16, 2008 | 10:12 PM
Whats a fair price for a oil change,xj8
Reply 0
Subscribe
Currently Active Users (1)
