Unusual brake wear.
Old Apr 8, 2011 | 11:04 PM
avt007's Avatar
Default Unusual brake wear.
I thought I posted this before but can't find it, so here we go again.
My front rotors have strange wear. The shiny area right by the hub is more worn than the rest of the rotor. It is the same on both sides of the rotor, and both front brakes are the same.
Anyone seen this before?
Old Apr 8, 2011 | 11:47 PM
plums's Avatar
C'mon, be honest. You just wanted to show off your shiny new hoist
Old Apr 9, 2011 | 09:30 AM
luc's Avatar
luc
being more worn mean that either the pads or the rotor are slightly thicker/make contact earlier in this area, since that correspond exactly to the part of the rotor that has not be machined for the grooves /holes, my guess is that they removed some rotor material when they drilled/holed the rotor
Old Apr 9, 2011 | 07:29 PM
avt007's Avatar
No, that wasn't the reason. honest! I was chasing a vibration under braking, but I may have it, in another post titled "rear end wiggle" or something similar. I'm hoping my braking problem disappears after the bering issue is solved.
hunter34
19
Sep 14, 2022 11:09 PM
jjlu2
Jan 29, 2016 07:02 PM
42Ajd
Dec 30, 2015 09:45 AM
xjrjag
Sep 24, 2015 10:08 PM
42Ajd
Sep 21, 2015 07:37 PM
