Upgrades to XJR
Old Nov 15, 2014 | 08:17 AM
Garyres's Avatar
Default Upgrades to XJR
Hey guys. Not sure if anyone has done it, but I highly recommend the Parrot for blue tooth. Works flawlessly. And is a must.
The car is getting new headlights today. Really think the stock is not up to par with any modern car today. They need to be much brighter. Where I live on Long Island, at night, the roads are dark, and its difficult to see. I will let you know what I (mechanic) did to the headlights, and how they are when I get it back. I drive my 2015 Navigator regularly, and I can tell you that the 13 yrs difference in the two cars might as well be 25, as for the lights. The stock lights are not up to par. I think they are dangerous.
Old Nov 15, 2014 | 11:49 AM
vincent661983's Avatar
I would suggest you do retrofit projector headlight with HID.
I found a guy in queens college point can do it
The source is coming from our fellow member did it before
Old Nov 18, 2014 | 04:54 PM
TreVoRTasmin's Avatar
If your mechanic puts a higher wattage bulb in your headlights, remove them immediately and find a new mechanic. The wiring is sized based on the standard wattage, over time your connectors will melt and the wiring itself will turn silver from the heat.
dsnyder586
Dec 29, 2024 07:39 PM
Donzi
Sep 17, 2015 01:29 PM
Ipc838
Sep 13, 2015 03:27 PM
lickahotskillet
Sep 11, 2015 07:54 PM
Mike Green
Sep 7, 2015 12:39 AM
