urgent help,please about the wheel hub stud
Old Aug 17, 2013 | 11:04 AM
vincent661983's Avatar
Default urgent help,please about the wheel hub stud
please help me for the information ASAP
the story is that I just obtained a new set of 20 inch running 5X108 and stud 12.5mm stud so I have to use the wheel adapter.
I found the 12.5mm lug nut is too small for X308 wheel hub stud and that I tried the 14mm nuts but it it biting the thread but I am not able to tie it up and lose.
I am so helpless and desperate for answer because my current set has to be ready for another Jag guy from the forums.please share any information
something like the following link of Acorn open lug-nuts
14mm x 1.5 Acorn Bulge Open End Low Profile Lug Nuts 24 Short Conical Lugnuts - mywheeladapters.com
Old Aug 18, 2013 | 12:00 AM
jimlombardi's Avatar
Coventry West sells wheel lugnuts for various XJ wheels:
Coventry West, Inc. - Online Store
Call them to see if they can help you find the lugnuts you need.
Jim Lombardi
Old Aug 18, 2013 | 12:08 PM
avt007's Avatar
The part number for the stud is JZB100064, but I can't find a thread size for it.
Old Aug 19, 2013 | 02:05 PM
Cabezagrande's Avatar
The X308's use a 1/2"-20 thread on the lugs, not metric. A holdover from their old US involvement, which is why they are on the old Chevy 5 x 4.75 bolt pattern as well. You should be able to find the half-length nuts you'll need for the adapters at any auto parts store. Keep in mind that the X308 comes from the factory with "cannon" nuts (otherwise known as shank nuts), and that the adapters will probably require a tapered nut.
Old Aug 20, 2013 | 04:25 PM
thank you and it was correct for use a 1/2"-20 nuts, I went crazy trying out all nuts and finally found the perfect one for perfect fit. I will load the wheel swap thread soon
lickahotskillet
Oct 18, 2015 09:51 AM
lickahotskillet
Sep 11, 2015 07:54 PM
iownme
Sep 11, 2015 02:57 AM
Joey T
Sep 3, 2015 05:31 PM
innzane
Sep 2, 2015 10:08 AM
