Vacuum line to brake booster removal
Old May 28, 2021 | 08:24 PM
mike32966's Avatar
Default Vacuum line to brake booster removal
Quick question, how does the hard plastic vacuum line that runs to the brake booster on a 2000 XJR separate from the throttle elbow? Doesn't seem to want to come off and I'm wary of breaking 20 year old heat hardened plastic fittings.
Mike
Old May 28, 2021 | 09:08 PM
Vonnslingo's Avatar
I broke one a month ago order new hose and the insert...I don’t remember who from sorry I fought getting the insert out finely used an ez out..
Old May 28, 2021 | 10:18 PM
M. Stojanovic's Avatar
Originally Posted by mike32966
... how does the hard plastic vacuum line that runs to the brake booster on a 2000 XJR separate from the throttle elbow?
Very easy - first, push the pipe and the black plastic collar at the elbow bush inwards; then, while keeping the plastic collar pressed against the elbow bush, pull the pipe out.
Plastic collar:
Old May 29, 2021 | 10:08 AM
mike32966's Avatar
Thanks, that was easy! Unfortunately the plastic collar came out in multiple pieces probably from a combination of heat damage and me poking and pulling on it. Another order for ebay - C2S15816
Old May 29, 2021 | 07:18 PM
Vonnslingo's Avatar
The connection on the throttlebody that it all goes into is a little brass insert I bought that piece it was broken on the inside That is what I convinced myself at least. Anyway to get that piece out that’s what I used an easy out on it was the brass insert
Obi
Mar 6, 2021 03:52 PM
tapollo
Dec 21, 2013 10:02 AM
dtown_50187
Jun 3, 2013 04:12 PM
afonda
Feb 22, 2011 08:38 PM
