Vacuum lines on fuel pressure regulator?
Old Sep 26, 2016 | 09:35 AM
4litre's Avatar
Default Vacuum lines on fuel pressure regulator?
2 things...is there a hose that connects to the end of the fuel pressure regulator and where does the J shaped hose under the throttle body connect to...
Old Sep 26, 2016 | 11:19 AM
Mark SF's Avatar
Can you see how "question about vacuum hoses" would be a far better title for the thread? When people are searching for info in years to come, do you think your title will be helpful?
Yes, there is a hose that connects from the right hand intake to the FPR. It is for vacuum so that the fuel pressure varies with intake manifold pressure.
Old Sep 26, 2016 | 05:11 PM
avern1's Avatar
The small elbow shaped hose is cooling system connected. It is directly below the throttle body and is oriented about 45 degrees to the left side of the engine.
A real bear to change after everything is back in place and you discover the hose is leaking ask how i know LOL
Old Sep 27, 2016 | 02:21 AM
4litre's Avatar
Right...thanks. And it would just a bit more helpful if you tell where on the right hand intake manifold I might be able to find this hose. Just in case people read this in the years to come, know where it is exactly...
Oh man thanks I need to get that hose back on the right track quickly then LOL. Where does it hook up to please?
Old Sep 27, 2016 | 07:35 AM
avern1's Avatar
Attached is the relevant pages from the tech manual for the FPR hoses and the cooling hoses.
File Type: doc
Old Sep 27, 2016 | 07:54 AM
4litre's Avatar
Thank you so much!
tadbyd
Apr 5, 2018 07:57 PM
Greencar89
Jul 24, 2017 08:28 AM
Boo
Sep 16, 2016 04:11 PM
Johnny6jag
Sep 5, 2016 10:19 AM
zombiewoof
Aug 30, 2016 11:17 PM
