valet switch
Old Apr 29, 2013 | 02:16 PM
x300man's Avatar
Default valet switch
as my key fob has not worked for some time i have been opening and locking car with "master key" i/e the black key, not a problem i can live with it ,BUT have pressed VALET BUTTON when cleaning ,how can i get valet switch off ? i can open boot with key but that is a pain,having to stop engine and take key out of ignition, if i disconnect battery for a while and reconnect will that do it or what problems may it cause, thanks to any one whocan help
Old Apr 30, 2013 | 03:32 AM
Yala's Avatar
mine switches off after i use the master key to open the boot once.
Old Apr 30, 2013 | 03:50 AM
adriaxj8's Avatar
The same issue happened me yesterday. I solved the problem by openening the car using the trunk. Then valet mode was off.
I hope it helps you
Old Apr 30, 2013 | 08:35 AM
JimmyL's Avatar
I had this problem. It turned out to be broken wires in the RH boot hinge. See if your trunk lights and license plate lights work. I know it sounds strange, but it has happened to many people.
Old Apr 30, 2013 | 01:00 PM
x300man's Avatar
THANKS YALA and ANDRIAXJ8 opening boot "trunk" to open car did the job thanks again guys
1100me
Oct 1, 2015 11:49 PM
goingjag
Sep 30, 2015 09:27 PM
ziondio
Sep 29, 2015 01:58 PM
Jzar
Sep 27, 2015 02:55 PM
